I am lost as to where this clunk is coming from in the rear of my whip. I did the following mods below and can't seem to pin down where the issue lies:
1.) Swapped OEM Struts with Koni's Sports with Ground Control coilover kit.
(Installed TL-S bushing (fronts only), new TSX bushing (rear), new top hats (4) and hardware)
2.) Installed Apexi WS2 Exhaust (posting a thread on this one in the other section, but important to know for the question above).
Here is what I have done to correct issue so far:
1.) Tq every bolt to OEM spec twice with two different Tq wrenches.
2.) Tq the OEM rear sway bar links with Progress RSB (twice too).
3.) All Struts are set to Sport setting with 360 degree turn (checked twice as well)
Other important factors to help the reader:
1.) Install all new struts with new OEM bolts/w nuts (new hardware) 3 weeks ago
2.) Installed Progressive RSB 9 months ago
3.) Installed new NAPA rear sway bar links 9 months ago as well
4.) Car is not slammed and is set to the highest it will go, which is about a 3 finger gap all around.
Please take a look and let me know what you are thinking. I really have no idea what my next step is besides replacing the end links. However, it is low miles with less then 7K on it and installed with RSB 9 months ago. When I did the install of the rear struts, the end links were still stiff.
TIA
TIA
