1 - 12 of 12 Posts
Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator you can play around in there and the calculator will show you results visually, first input the info of your stock set up, then input the new set up and you will see the clearences, offset, you can also adjust tires live so it wil show you what the tire size will look like on that rim and will give you a speed calibration calculations as well. its a really great site :) hope that helps
~De5
· From Nissan to Honda
CU2 guys step in please........
Lou, please post the offsets as well. The width in the rear might not be a problem depending on the offset.. Also, need to know:
What are you dropped on?
Any camber kit, or natural camber?
What kind do a stretch do you want to run (this is your daily driver, that you drive into the city right)?
Discussion Starter · #6 ·
I had 18x10 all around one I would have kept them problem was I knew nothing about fitment and at the shop they did not have the tools to stretch the tires so on top of having 18x10 all around I had tires that were 265/35/18 the car look like a monster truck lmao I was so mad but now I learned come to the forums for advice lol
Sent from AutoGuide.com App
1 - 12 of 12 Posts
