About every 10K miles, you will get a notification on the dash that will be a letter and a number. For example A1 means you need an oil change.
Acura calls this the "Maintenance Minder". If you google it you will find lots of sites that tell you what the codes mean. Here's an example.
Acura Service Codes | Acura Maintenance Minder Guide | Motorcars
Most of the items can easily be done yourself. Transmission fluid change and brake fluid change are important and critical, so you may want to have the dealer do those.
