1 - 2 of 2 Posts
I just installed new rotors and up front less than two months ago. I just noticed on my way home that if I let go of the steering wheel and brake the car pulls hard to the left. Also I noticed alot more brake dust buildup on the driver side than that of the passenger side. What could cause one side to brake harder.
Thanks
That's Doctor
When you did your brake job, did you thoroughly lube up the caliper slider pins? If your right side is frozen and not sliding as easily, your braking power will be unbalanced. I suggest you pull apart your right side and make sure everything is clean and sliding freely. If so, take apart the left side and inspect it. I had a similar issue on my vintage Accord and it turned out to be a frozen caliper causing the bias.
1 - 2 of 2 Posts
