1 - 3 of 3 Posts
So I was changing my interior lights to LEDs yesterday and while I was working on the driver's door light, it sparked. The light went dead (even with the OEM bulb).
So I checked (and removed the fuse) inside the car that said interior lights. I put it back in. And the door lights began to work. BUT, now when the door is opened, the map lights and gauge cluster don't light up.
Also, my alarm system (factory) is not working ever since when I press unlock or lock using the key fob remote. My power locks switch on the door panel is unresponsive too. My headlights switch (parking and head lights) don't work either.
----->BUT, EVERYTHING WORKS when the car is TURNED ON or to the ON POSITION (check engine mode, position II)
I tried removing the neg. battery cable and then re attached it. No improvement.
Is there a fuse somewhere that can fix this? Any ideas? Did I kill my car's electrics?
Thanks,
:newbie:
Sounds like you did blew another fuse. Try fuse 7 , 10A ?
:rollsmile: THAT WAS IT!!! Thanks for the help!! May good CARma come your way hahaha!! lol:smash:
You're the man lol! :goldcup:
I rep'd you by the way
1 - 3 of 3 Posts
