1 - 2 of 2 Posts
So I just got pulled over and found out none of the lights on my trunk are working. The tag lights, tail lights, and reverse lights are all out! The brake lights and turn signals still work but they aren’t on the actual trunk. Can you guys think of anything that could be shorted or what fuse may be blown?
Did you have the trunk wiring harness recall done? Because mine wasn't done and I had trouble similar to you. Since I don't like going to the dealer I fixed the broken wires myself that the recall would've covered and solved the problem.
1 - 2 of 2 Posts
