so wut's the tq spec for those bolts ? ... and do i need new bolts ?
Bolts? The spark plugs screw in like bolts...I guess that's what you mean.Andynolife said:so wut's the tq spec for those bolts ? ... and do i need new bolts ?
spark plug wire??? o_0Andynolife said:btw .... do u guys think it's a good time to change the spark plug wires while i put the new spark plugs in ? ...
and wut particular wires r good for such set up ?
Thanks
srry .. haha .. my mistake .. we r direct injection .. ~ :ben:SAZABI said:spark plug wire??? o_0
The K24 is NOT direct injection. Correct me if i'm mistaken, but direct injection is where the fuel is directly injected into the combustion chamber, with the fuel injector located similar to the spark plugs. Our fuel injectors reside outside the combustion injector, on the intake manifold. I think the K20 used by the Honda Steam is direct injection engine.Andynolife said:srry .. haha .. my mistake .. we r direct injection .. ~ :ben:
but how come NGK's website listed that Laser Iridium spark plug is original equipment ?? where is Noel ?
yup ... ~ thx for clearning things up guys ~Noel said:MemphisRheins - Meguairs NXT Wax.
Rmatic09 - Competition racing ECU, not a street ready product.
Andynolife - Andy, yes individual ignition coil packs, but more commonly associated with being direct injection as coil wires are not necessary. I think you're getting confused with spark plugs and spark/ignition leads?
yup ...Noel said:Yes, it seems Honda has implemented iridium plugs as standard equipment on i-VTEC engines. However, different grade/temperature type ratings would still be important under specific conditions.
