The power steering pump on my 2007 Acura TSX is leaking from the O-rings from both hoses. I need help finding the O-rings for both hoses. Any help is greatly appreciated.
46746
46747
These o-rings are a very specific size and you will have to get them from Honda or Acura. I recently replaced mine and the part numbers did cross over to Honda parts (Accord most likely) so you can avoid the gouging from Acura. I think I paid $2-3 each for them.
Thanks and I need the part numbers.
Acurapartswarehouse.com has excellent blowout diagrams so you can see you have looked up the right part. I use them frequently for part lookup.
Discussion Starter #5
] Solved Solution [
If anyone else is searching for these two parts.
Part Number Part Name
91370-TA0-000 O-Ring (14.4X1.9) jump outlet hose
91345-RDA-A01 O-Ring (13.0X1.9) inlet joint on the pump housing
