1 - 2 of 2 Posts
I just upgraded my factory acura battery to an Odyssey battery model PC925MJT. Is the battery suppose to sit the normal way or sideway? How did you guys installed it?
If I install it the normal way (facing up), I have to remove the battery tray in order for it to fit. The battery tie down bracket sits a different position then normal and the bracket is a little loose unless I add washers. Also, the battery is packed tight against the intake housing and the air vent.
If I install it sideway then I can keep the battery tray and the battery tie down bracket sits the same position as factory battery and it tightening up just fine.
That battery can be mounted any number of ways. So whichever way it fits is good.
Sent from AutoGuide.com App
1 - 2 of 2 Posts
