What the heck is it? Is that supposed to be a collection point or something? Is it leaking there because I have too much oil in the engine? I measured it with the dip stick and it's definitely above the top hole.
How far above the top hole? Overfilling can cause pressure issues in the motor.What the heck is it? Is that supposed to be a collection point or something? Is it leaking there because I have too much oil in the engine? I measured it with the dip stick and it's definitely above the top hole.
youre right. crank is far away. hmmmNo it's definitely not left over oil from crank seal as the crank is nowhere near it. I have wiped it before and it started collecting again after a few WOT of boosting.
This is not the best advice. At operating temperature, both of those oils you listed have the same viscosity. Higher viscosity does not mean "less leak". Where the leak (if there is one) is located is probably more paramount to the loss than any other factor.Go to a 10-30 too if you're not already. Won't leak as bad as a 5w oil and its better for hot weather anyways.
Checking first thing in the morning is fine too.. After all, most of the oil should have made it to the sump by then.. keep the level in the hash marks (preferably on the higher side) and you'll be fine.The proper way to check engine oil level is to warm the car up (drive/idle, whatever), then park it on level ground, shut it off, and wait 10 minutes and then to check.
If it is excess oil, thats no bueno. Excessive crankcase pressure is a no no![]()
No where in the manual does it say to use 10w-30Look in the manual, 10-30 can be used for higher ambient temperatures I.e. late spring/summer. 10w will "cling" better especially in warmer weather for easier startups.
No its not. The motor needs to be at operating temperature because thats how much oil is in the motor when the engine is running...Checking first thing in the morning is fine too.. After all, most of the oil should have made it to the sump by then.. keep the level in the hash marks (preferably on the higher side) and you'll be fine.
I wouldn't worry too much if you're just a little (1/4 qt or so) over. You just don't want oil to be churned by any rotating parts other than the pump itself. You'd have to be severely overfilled to get a leak like you're describing. Not so much a matter of crankcase pressure.
You're right, I must have the recommended viscosity mixed up with another car or its in the Honda service manual HOWEVER, it's not really a bandaid fix since 5w and 10w-30 behave the same at op temp.. I see nothing wrong with changing weights for the time-being just to help with some leakage. As long as the temps aren't hitting below 40 or 45F, you'll be fine.LOL....
Ok, do not change your oil viscosity. I have no idea what the hell it is with everyone and trying to bandaid there freaking problems.
Secondly your telling someone that lives in socal to change to 10 weight. Do you realize how much the temperature can swing there?
Have you ever seen what happens when a crank even just barely bashes through excess oil? Or even when the oil is to thick and cannot be freely pumped by the oil pump? This creates cavitation and its not pretty once it starts.
Everyone needs to stop with the advice to cover up a problem. You want to do that to your own car, go right ahead. Dont offer that crap up to someone else. Find the actual problem and fix it.
All of Hondas Rs run 5w20. They switched the Ks from 20 because of the way the motor shears the oil to a lesser viscosity. If you run 5-7k on 30 oil it shears itself down to around 20. Its not a bandaid fix when it fixes hundreds of thousands of engines.You're right, I must have the recommended viscosity mixed up with another car or its in the Honda service manual HOWEVER, it's not really a bandaid fix since 5w and 10w-30 behave the same at op temp.. I see nothing wrong with changing weights for the time-being just to help with some leakage. As long as the temps aren't hitting below 40 or 45F, you'll be fine.
There was a time that the recommended oil was 5w-20 for these engines but after finding that the engines were wearing relatively quickly, the recommendation was changed to 5w-30. Bandaid fix?
The level isn't much of a science, we're not running dry sumped engines here..
Fortunately, unless its SEVERELY overfilled like I said, it won't get churned by the crank. If anything, the balance shafts somewhat act as a windage tray.
OP- search around how to check your PCV valve. They can get lightly carboned up and stick causing the crankcase to not breathe right. You could just replace it to be safe since its a relatively inexpensive part. Maybe totts can chime in on this one
Didn't necessarily fix, just hopefully slowed the wear rate.All of Hondas Rs run 5w20. They switched the Ks from 20 because of the way the motor shears the oil to a lesser viscosity. If you run 5-7k on 30 oil it shears itself down to around 20. Its not a bandaid fix when it fixes hundreds of thousands of engines.
The problem isnt at operating temperatures. The problem is at cold start, which is the most important part of an engines life. If cavitation starts at start up it usually does not stop. The crank isnt the only thing thats spinning, the oil pump is too.
Just remove the PCV, and shake it near your ear. If you hear it clicking back and forth its fine.
