Hey guys I’ve had this leak in the back of the engine on my 05. It could be the vvt solenoid but it looks more like the sensor underneath it. The one right above the oil filter and right under the vvt solenoid. I have no idea what it’s called though. No diagram or person can seem to tell me. I don’t want to pay a mechanic just to tell me the name of the sensor. It almost looks like a spark plug. I’ve included a poorly taken picture.
48452
2008 TSX auto
2008 TSX auto
Did you mix up #5 and #15? Diagram shows #15 is an o-ring.
No mix-up. Item 15 in first link is the pressure switch. Item 5 in the 2nd link is a seal for the VTC oil control solenoid.
Oil pressure switch all day and aye!!!! When you torque it in, you will see thread sticking out from the engine. THIS IS NORMAL! DO NOT over torque or that aluminum will pop and you will be sol; be careful on torquing it back in the hole.
