Lmao. Lips are sealed. Dirty mind had to come out sometime.Where can I get it for fast, easy and cheap in around Markham?
:laugh:Lmao. Lips are sealed. Dirty mind had to come out sometime.
So no tail pipe sniffers?Drive clean tests are all at a fixed price, $35.00, govened by the Province. Since the beginning of this year the test only involves hooking up to the Engine diagnostic port. Had mine done a couple of weeks ago at Oil changers. I was in/out in 10 minutes.
Nope, apparently they dont need those readings anymore. Strictly take readings from different sensors via the ECU.So no tail pipe sniffers?
See that I am not 100% sure about, because I've been hearing mixed things as well on a few people having test pipes. My shop has told me that with a test pipe, you should be able to pass this new test...then again I've read the opposite first hand. So who to believe I am not sure.... so if someone is running a test pipe, has no check engine lights, technically they pass?
