So, check this out ...
For the last 5 years The D light has been flashing. It would flash from intervals of one week - randomly - to now every minute ... and then stops. ... Annnnd then back to flashing. Needles to say the check engine is on currently.
But get this ..... The check engine light was on constantly for the last two years but I filled up with Shell V Power instead of any other gas once last year which broke the Check engine light curse. With this said the check engine light is on constantly but may cut out for the next 15 minutes even when parked and then restarted.
I've changed the Transmission pressure switch three times to see if the switches were faulty; oem, aftermarket, junkyard oem with harnes; nothing.
which leaves a few things assuming that the problems are not related; the transmission pressure switch for the flashing D or a faulty ecu for the p1705 ... aftermarket starter installed 2 years before the problem ignited.
transmission fluid upkept and filter changed ... Go!
( after 5 years im tired of looking at it and about to submit to a trans specialist)
