1 - 9 of 9 Posts
im sure this is the same for 1st gen and 2nd gen so might as well post it here since people visit the 1st gen side more :laugh:
our dipsticks are orange, which is ugly as hell :squint: i have a huge can of black spray paint left over from summer when i spray painted an extra set of emblem to black as a small test project. i am wondering if i can use the same ones for the dipstick? i forgot the brand of it but its primer + paint all in one can.
question is....can i jsut use that to paint the dipstick? or do i need engine paint or high heat paint for it?
also...do i have to do it like my emblem, where i have to sand it first then paint?
I used high temp flat black on mine but honestly any paint should work. I always sand down the plastic a little bit before painting it.
^ thanks ink :thumbsup:
i used a non high temp flat black spray paint and its been good for almost a year now. make sure to tape up the parts you dont want painted such as the little o-rings and metal rod itself.
Discussion Starter #5
:thumbsup:
What to put here?
Don't paint the part that goes into the dipstick hole. It won't fit if the paint is too thick.
The other white meat...
That just sounds naughty. With a little lube, anything will fit.:leghump:
Discussion Starter #8
1 - 9 of 9 Posts
