1 - 7 of 7 Posts
From Nissan to Honda
Long story short, my mechanic was unable to remove the factory camber arms to install the Ingalls Camber kit I purchased because the bolts connecting the arms looked stripped (they indeed did).
I guess a previous alignment tech thought it was adjustable arms and tried tightening them? :bill:
In any case, anyone know the OEM part number? Sad part is, I need it for both sides :squint:.
Thanks in advance.
The other white meat...
If you go to the Dealership, they typically can pull up a exploded view of the suspension components. This will allow you to point out which bolts you need.
  • Like
Reactions: JTrix215
That's Doctor
I order all my OEM hardware and parts from Acura of Boston: OEM Acura Parts & Acura Accessories - Bernardi Acura Parts & Accessories
You can verify these part numbers if you want but here's what I found:
2004 & 2006 car side bolt: 90173-S84-A00 ($2.13 ea)
2004 hub side bolt: 90121-SEA-E01 ($2.55 ea)
2006 hub side bolt: 90121-SEA-E10 ($2.55 ea)
2004 hub side nut: 90215-SEA-E00 ($2.75 ea)
2006 hub side nut: 90215-SEA-E10 ($2.75 ea)
1 - 7 of 7 Posts
