If you are riding around with your Ebrake up. 2. Caliper won't open and should be replaced or rebuild. 4. Replace disk as well cause there garbage turning them might save you 10 bucks each better to replace. Finally Good luck
I’m assuming this is a 2009 or 2010 model. The rear calipers had sticking issues from the factory. You need to either get them rebuilt or replaced with a brake upgrade kit.
That's all assuming that it isn't the brake pad shim; that little tin piece that holds your brakes still while in the caliper. It shouldn't be this because you would hear it as well. If this is a first gen tune in for I'm changing rear pads and rotors this month.
If not like the other guys said your the caliper may be down prematurely as a result of a faulty manual brake. That's happened to me as well. It's rare but it can happen.
Oh and if this is second gen I hear that those calipers are just a failed design all together. Some guys change them every time they do their brakes 🤷🏾♂️
