$155 plus shipping
Venting the gas from super heated brake pads improves overall brake performance. Of the various venting methods, slotting has the clear advantage. Slotting, unlike drilling, is not prone to cracking. Plus drilling delivers considerably less active braking surface - 8% less than Power Slot Rotors. The tapered slot also channels brake dust and heat away from the rotor and pad for improved braking ability. Power Slot Rotors are CNC-machined and come with an anti-corrosion plating that looks great behind custom wheels.
CNC Machined!
Anti-Corrosion Plating!
Slots Keep Rotor Cooler!
Slots Keep Rotor Cleaner!
Improved Wet Braking!
Installation: Installs exactly like a stock rotor.
CNC Machined!
