1 - 14 of 14 Posts
Hey guys im changing the rotors and breaks on my 2005 Acura TSX the rear end of my car and i came upon this..
<a href="http://s1328.photobucket.com/user/Cochinoalex/media/Acura%20TSX/photo2_zpsa14a1526.jpg.html" target="_blank"><img src="http://i1328.photobucket.com/albums/w527/Cochinoalex/Acura%20TSX/photo2_zpsa14a1526.jpg" border="0" alt=" photo photo2_zpsa14a1526.jpg"/></a>
I need some tips and help also the size of the screw so i could buy a new one
but does anybody know how i could take this off?? :tard:
also sorry if im in the wrong section im new to the forum life
To remove: if you have access to a dremel, cut a slot to stick a flat head screwdriver in there. The best tool to use would be one of those punch screwdrivers that twist the bit left or right when you hammer the end of the tool.
skip to about 1:40, the 2 hammer method worked for me but i had more head left.
The heat cycling from the brakes really rust welds them on there.
When i got new rotors, i bought a few new screws too at the honda dealership. I used the screwdriver and hammer method, where you hammer the screw driver a few times and then torque it
Penetrating spray and the screwdriver and hammer worked for me. No need to replace the screw if you tear it. I hear its only there to hold the rotor during the assembly line process.
Sent from AutoGuide.com App
Don't replace it. Wheels will hold discs enough.
Drill a hole in center then use a "turn to left". This thing you use on a drill when going in reverse will screw into it and unscrew the bolt.
I had the same problem when I changed my rotors. I took that screw to autozone and found some that are the same. I threw the bag that came with it away already so I can't tell u the exact size but if u're still in need of one i can send u one free of charge but like mention already u really don't need that screw.
1 - 14 of 14 Posts
