1 - 6 of 6 Posts
My 2004 aura tax will not start. It will if I put my foot on the gas pedal. But it runs really bad when I do that. What could be the problem
Hi Jacobely 80, welcome to the group. There are many things that cause that. To better help you, hook up a scanner to the OBD ll port under your steering and pull the codes.
Without the codes, it would be much more difficult to assist you with the only given information.
Have you tried to clear the code after you replaced ECM and plugs? I usually have to clear my codes after a repair. I'm not sure if that will help as I've never experienced that code, just trying to help.
1 - 6 of 6 Posts
