· Premium Member
I had this problem a while back but didn't bother asking since I was the only driver of my car but I figured I might ask anyways...
So I bought the flip key from HeelToe and it works perfectly. I got it programmed at Acura and it works. The only issue is I had to program the remote myself so I searched it up and did it. The only thing I'm having an issue with is that my flip key remote won't work along with my stock Acura remote.
So basically I can only have the remote to work on one or the other, anyone else have this issue? Figured someone should know. I have an 2004 TSX if that helps, so no seat memory or anything.
When you reprogram your remote you need to have both remotes with you. It has to be done at the same time. I believe only two remotes can be programmed at a time. I tried doing three and only two of them worked.
· Premium Member
Yup I had both remotes with me and I programmed it both at the same time. So you set the car to program mode then you press the buttons on both the remotes etc... Still didn't work. It was either one or the other.
· Premium Member
do you have memory seats?
If so, and both are driver 1 (or driver 2), you need to hold lock and unlock I believe to unlink the memory seat function
I don't have a memory feature in my car since it wasn't available for the 04. I tried unlinking them both by holding the lock and unlock button, then reprogramming it but it doesn't work.
