1 - 1 of 1 Posts
Ok so I have a 05 TSX the front passenger side window stopped working so I replaced the motor/actuator and then the switch still not working. If I take that switch to the rest window it works but none of the switches work the front ps window. I have tested the regulator and the switch. The only odd thing is if I use the master switch the passenger switch clicks not the regulator the switch one click per switch click. There is a good connection from the ps switch connection to the motor actuator connection. Please help
1 - 1 of 1 Posts
