1 - 7 of 7 Posts
David Path
The wheels I'm looking at are the Varrstoen 1.1.1 with the size 18x9.5 +30. IMO I think that it is too wide and I'm afraid it may stick out too much.
I have ingalls cambers in the rear and no cambers in the front. I don't know how low I am, but I have about a half an inch finger measured from the top of the tires to the wheel well.
I also know I will have to do some work with the fenders on all four sides.
Tires, planning on running 225/40.
1. Are there any members running this size? If so pictures please, because I have searched on the forum and eveything popped up for 18x9.5, but nothing for +30.
I want to get a general idea of how it look on a tsx.
DiRTBAG Jose!
you can also use rimtuck.com to look other tsx's wheel specs.hope that helps
n/a
from what i've gathered, you will be fine in front but with only a stretch. 215/40/18 w/ a skinny tire i.e nankang nsii. If you run 225's you will risk rubbing pending how low you are.
Honestly, if you google "tsx 18x9.5 +30" you will see people that ran this set up.
1 - 7 of 7 Posts
