Hey Guys- first post here, but have been reading and lurking since I picked up my 2012 TSX-Tech V4 about 3 months ago. I have some IJDMToy 6000k bulbs and the LED DRL kit to install tonight, and I just had a quick question about removing the front bumper.
I have read the thread several times regarding taking off the bumper (8 clips on top, 12 on bottom, 1 screw in each fenderwell).. But I was curious if I had to remove the ENTIRE bumper since I only need access to the bolts below each headlight assembly to remove them and install my 6000k low beams.
Is it possible to just take off the top 8 clips, each screw on the side, and then just pull each corner of the bumper out enough in order to access the headlight assembly blots? Or do I need remove the 12 clips underneath and physically remove the entire bumper as well?
Just trying to make this job as simple as possible... Also, I have a massive fear of not being able to get the bottom clips back into the bumper and liner correctly.
ANY help you can give me would be greatly appreciated. Thanks guys!
