Acura radio PCB board serial number and code retrieval
Step 1 - Retrieve radio serial#
Acura will have two ways of retrieving the radio serial#.
* Type 1 or Type 2
* DEPENDING ON THE YEAR
Type 1
Acura ( For all 2001 and up vehicles )
* Turn the vehicle's key to the "on" position.
* Press the preset buttons 1 and 6 at the same time.
* Turn on the radio.
* A 10 digit serial number will appear on the radio display, (if stereo was locked up at the time).
* There will be 10 characters in the radio serial #.
* A U followed by 4 numbers and an L. followed by 4 numbers.
* Example, your display will indicate, U5123 L1235. ( SN #:51231235 )
* Or will indicate all 8 numbers at one time. Example: 51231235.
* Please document this number, as you will need this number for the form below.
Step 2 – Get the code using the link below
https://radio-navicode.acura.com/
* You will also receive your radio unlock code, via email.
Note : If the code cannot be retrieved because it is locked, call the Acura Customer Relations at 1-800-382-2238 option 6 to unlock and retrieve the code.
* Type 1 or Type 2
Type 1
