1 - 8 of 8 Posts
I recently got an 06 TSX and I left my maplights on resulting in a deadbattery. Luckily, I got a friend to help me out but I need the radiocode now :( After searching and searching, someone mentioned the site https://radio-navicode.acura.com/
I entered my VIN code but it says it isn't valid, but I also notice the zip code won't allow me to enter 6 #'s/letters assuming its meant for americans only. Is there any other way I can retrieve this without calling a dealer at all? I live in Canada
Another thread about this... Sorry but, this has been covered multiple times...
If it is not on the side of the glove box, and you can't find it online, you must call the dealer. They should be willing to help you withtout any fees...
EDIT: check in your manuals if the previous owner noted it.
I understand, not trying to be an ass, sorry about that. Mine is still sticking beside my glovebox so I do not needed to check online or others.. At least, I gave you my thoughts, not only saying to do your search! :) Hope this will help you! Good luck!
My 2005 TSX has the radio code on a separate card and my wife's 2006 TSX has the radio code printed on the cover of the owner's manual. Neither has the radio code inside the glovebox. Acura is very inconsistent with providing this information.
No they are pretty consistent, all of them come with a card that has the radio code on it, its a matter of owners losing them or not. If it gets stuck somewhere else that usually means the radio was replaced. The joys of buying used.
I realize this is a really old thread, but I found this on google and thought I'd give a solution to those who are searching.
Mate I had the same issue, I'm from the UK, and that free site doesn't work with non-US Acura's. Here is what ended up working for me.
I found a website that helps people with this problem, sent in my serial number and boom, radio code within 2 hours. Here is the site I came across:
Acura Radio Code - Radio Locked? We'll Unlock It!
Hope it helps some people out
Justin
1 - 8 of 8 Posts
