h1e1l1p
HI guys!
Ive read similar situation involving the Rear Camber in the TSX. I currently have a 05 TSX and recently had a courtesy oil change and Tire rotation from Goodyear. Everything went smooth and saucy until they found a problem when rotating the tires.
On the Front left tires; they found peeling of the tires on the thread area inside, where it wasnt visible. So they continued with the rotation and now that tire that has some peeling is now on the Rear left.
When consulting with me about that situation, they offered me a free 21 point inspection and found that my wheels were out of alignment,mainly in the rear. And I was recommended to buy a camber arm which from them cost $175, UNadjustable. But I decided to stop the inspection from there and shop for a camber that would best suit the needs.
I do have to admit that the rear axle of my car looks really unaligned, b/c the rear tires looks similar to these / \ slashes.
Here are the copy of the specs from the alignment:
Front left: Front Right:
Camber: .4 -.3
Caster:2.4 3.0
Toe: -.17 -.07
Rear Left:
Camber: -1.7 -2.5
Toe: -.05 -.02
First and foremost my question is: Is the rear really bad and unaligned from the specs above?
What type of camber is at a good price around $100 that are adjustable?
Are the front wheels adjustable to be aligned?
Oh! anyone knows the reason why my front left tires suddenly had peelings on the threads?
Any help on this matter would really help thanks!
HI guys!
Front left:
Camber: .4
Caster:2.4
Toe: -.17
Rear Left:
Rear Right:Camber: -1.7
Toe: -.05
