I've been hearing a creak coming from both sides of my rear suspension whenever I go over a bump or whenever I make a sharp turn. Currently I have a Comptech RSB, and the A-Spec Suspension installed.
I can also hear the creak if I jack the rear of the car up, and place some blocks of wood under one tire, and then lower the car onto the blocks.
I just changed from the bushings that came with the Comptech RSB to Prothane bushings and greased them up, but it did not fix the problem.
Can anyone suggest what steps I should take to diagnose where the creak is comming from? Someone suggested that I try removing the RSB completely and seeing if the creak goes away (only to narrow the problem down to either the RSB or not).
Thanks in advance.
Thanks in advance.
