Hey guys, as some of you know I stripped the allen bolts when installing my TL type S RSB into my TSX, thanks for all the help to everyone who chimed in, so got new endlinks and went with OEM,because i got the OEM ones I was pondering on how to prevent the allen stripping problem in a future thats being caused by the seized nut and I think i came up with a solution. now I wont know how well this will work until the next time I have to work on the RSB, but in theory it sounds pretty good to me. Since the seized nut is caused by the weather I decided to cover it up using this.
3/8 in. Rubber Screw Protectors (2-Pack)-78088 at The Home Depot
I greased up the threads with this first
Buy Permatex Anti-Seize Lubricant 81343 at Advance Auto Parts
then put a dab more of the anti seize grease into the rubber caps and put the caps on the endlink threads after torquing everything down to specs. Now theoretically this should stop the threads on the bolt from corroding, rusting, seizing and the rubber caps are just an extra step i decided to take to make sure that none of that will take place. let me know what you guys think.
the whole mod cost me $5.54, its better to spend the extra $5 rather than buying a set of new endlinks for $40-$75
~De5
~De5
