I'm currently in the process to removing my oil pan , the previous owner had put the Hondabond but didn't put it right and oil was leaking . I ran into a problem with taking off the pan all the bolts are off the pan is loose I just can't get it out due to the sub frame being in the way . I've read there is no need to lower the subframe . I loosened the passenger side motor mount and still no clearance . Is there a diy on how to remove the pan or any suggestion thanks
