I have hit 204k miles and really haven't had any major problems with my 2004 TSX. Until recently, I am having an issue with solenoid C, code P0979 DTC-22. SO, my question is; could this be a sign that the transmission is about to go soon or should I replace the solenoid which is inside the transmission housing. I am not that great of a mechanic, only simple things. Got a few opinions from shops, and the dealer. They all pretty much suggest I replace the whole tranny. Seems like I only have the problem in the morning on the way to work. "D" light flashing, revs higher than normal, then a hard shift. I pull over. then shut the car off and start it; it's fine after that. I think it could be the screen needs to be cleaned or the solenoid needs to be replaced. The only fear that I have is what if the other ones start to go then I might as well have replaced the whole transmission. With over 200,000 miles I think I am pretty lucky not to have had too many issues. What are your guys thoughts before I go spend $2500 on an overhaul?
