So I looked up for about a week why would my 05 tsx be grinding on 3rd, and reverse. Came across a bunch of forums stating I needed to replace the slave and master cylinder. I replaced the slave about 2 days ago and and bled it to make sure it worked. It was still doing the same thing (was able to drive it tho). I replace the clutch master yesterday but I haven't been able to get it to engage. Is there any other adjustments I should be making? Please HELP!!!
Also check the bracket on the clutch pedal where it mounts to the firewall. They can crack, making your clutch not fully disengage when you press the pedal. It happened on mine and others here.
