Donating TSXCLUB Member
Hi all,
I replaced my driver side low beam headlight bulb today (using some nice diy's). The bulb replaced just fine and is working well. However the left turn signal on the same driver side headlight stopped working afterwards. It doesn't even blink when I do remote lock/unlock of the car. Could I had unintentionally messed up some wiring while changing out the d2s bulb?
The side mirror and rear left turn signals work just fine.
Attached image is a different car, but the brighter light is the one that stopped working on mine.
2005 4door TSX
Bump, same problem with my 2005 TSX
When I lock or unlock the car, all the lights blink except the passenger side corner light. When I turn on headlights completely, it won't turn on as well, but low and high beam all work fine for both sides. The one flick on the headlight, the driver side lights up but not the passenger side. Definitely hoping its the bulb and not wiring problems, any ideas or suggestions please?
