Hi guys. Did anyone succeed in a DIY removal of the malfunctioning (trouble code 11 or 13) front ABS speed sensors from the front knuckle/spindle assembly after they were rusted to hell?
Mine are malfunctioning - front right - code 11 - and need to be replaced. After removing the 10mm bolt, cleaning the rust around the black plastic body and spraying some wd-40. I carefully managed to pry the body from the rusty knuckly using multiples of tiny screwdrivers to wedge it off. Even being super carefull I managed one partial crack in the body, once that was loose, the core of it was NOT coming out! Moving the plastic body with finger in clock/counter-clockwise direction immediately with almost no ressistance broke the plastic lose form the core. Shining the light in there I can see the wire going down into the something that looked like a completely rusted metal mass. I could not even tell where is the sensor core and where is the rusty knuckle. I have a feeling that no liquid spray will work on this as all I have to pull on is the wire. I'll give the acetone/atf fluid a try, but it looks like the whole knuckle will need to come off and the bloody thing will need to be carefully drilled out and cleaned. I guess it's possible to drill without removing the knuckle and then try to blow the remaining dust out, but that will probably result in the repeat of the procedure once the shavings that don't get blown out will attach to the magnet and cause interference.
So, any brave men or women who managed to get through this problem? If any of you took it to the mechanic or stealership any insight on how they got it out and optionally - how much did it cost?
:help:
:help:
