has anyone did reverse hid lights? i was thinking about doing them but not sure what the proper way is and the bulb size you would need. any info would be great thanks!
Thought about doing it, but found the cree LED bulbs that work pretty good in the dark. They look like mini HID bulbs. Plus I didn't want to risk melting the housing.
where you get those cree led bulbs from?
JLC lighting. Got them off a JLC vendor on azine, he's no longer a vendor though. The light output from the TSX in the video is not enhanced, that's how it looks in person.besides how it looks, how much light do you actually get onto the ground?
Where do u get those the second picture oneFrom my experience, I don't like these kind of cree 7440 lights:
These kind of lights only shoots in one direction. This means your reverse housing will not light up, only the light emitted behind. I didn't like this style because I want people to see that I am in reverse and often the best way to know is when the housing is lit up.
So I returned that style and got these:
The standard LEDs placed on the sides gives the reverse housing a light up look. So now I have great coverage directly in the rear and my housing is lit up.
If u find um post um up hahThose arebgood but there are even better ones that angle some led backwards so they actually reflect off the reflector... I'll see if i can find them
Sent from my SAMSUNG-SGH-I717 using AutoGuide.Com Free App
I think the difference is minimal but I could be wrong. Because the LED's aimed at the side has a radius big enough to reach back.Those arebgood but there are even better ones that angle some led backwards so they actually reflect off the reflector... I'll see if i can find them
I'd have to disagree a bit. LED do have a spread and it's in a cone like shape. It's definitely nothing like incandescent but definitely not linear either.Well led don't really have a radius... The only send light out in one direction and their spread is not alot and diminishes greatly if away from their degree of output...
So those are good but there are better.. I've been folowog a thread for a long time on hidplanet about reverse light led
