No it will notI mean I have a TSX stock clutch will it work with an RSX flywheel?
No it needs to be for a RSX type S, the base RSX will not work either. If you want a RSX type S flywheel you need to use a RSX type S clutch disk as well.OK, so from so more research I'm am seeing that I should return my new TSX clutch and get an RSX clutch with the RSX flywheel and it'll bolt right into my TSX?
