I have an '06 tsx, my driver seat heater works on LOW but doesn't work when I switch it to HIGH. Any ideas of what could be wrong?
I love my CL9!
Are you sure it's not working. I believe if you use the high setting, it turns itself off once a certain temperature is reached. Then, after it cools down a bit, it turns itself back on. If you use the low setting, it just stays on the whole time. I think that's what the owner's manual says.
Exactly what the manual states. Low is on at all times, High will cycle:eek:hsnap:
