Hi all
i have a 2004 tsx. i was installing the skunk 2 racing intake manifold and got to the end of the install, and then noticed that the upper rad hose now goes right through where the throttle body is now located. I have heard you need to use an upper rad hose from a civic si w/ k20 motor to have the hose clear the throttle body?
is this true or does anyone have any other ways to solve this issue?
i was also wondering if you can cap off the egr vacumn hose that normally goes into the egr plate on the oem manifold as with the skunk2 manifold there is no longer a egr plate...
any help is greatly appreciated.
