Me and my buddy just ordered the extreme bulk pack. Splitting the roller and that comes to like 80 bucks each. Now the hard part is installing it. Looking forward to it. Any suggestions on places to put it and what to do. ( obv first time at this.)
I got you!
First when it arrives, pick a warm day to install it. It will stick alot better and be more plyable if its warm. I suggest pulling all of it out of the box and laying it film side up in the sun for a few minutes. Again the warmer the better but to a certain point it doesnt make a difference.
2nd...your getting the roller and that is self explainitory lol
3rd...pull all plastics off. like it was said before this stuff is going to be sticky and if you touch it to something its going to leave a residue. So plan exactly where you want it to go and move everything out of your way. You want to use it on flat areas that have thin flexable metal, so you might be able to cut a few pieces in shapes to fit in areas but again dont leave air pockets because that is just wasted product.
4th...Areas to look at. When you pull out everythign in the trunk the outter panels/skin are a must cover. You will see what im talking about.
5th...if you have enough after doing you and your buddies trunks, the doors are another great area. The flat thin metal makes a great spot to stick it to. Be ready to take some time to take the panels off correctly and pull the stock sound deadner plastic away (but keep this, it does do something) and then stick it to the outer skins in the door. Its gonna be messy as hell but should stick back pretty well.
6th...make sure you clean the metal well. Dynamat loves a little heat and clean metal. Dirt will do nothing but keep the dynamat from sticking.
that should be enough to get ya started. Just the first things that came to my mind if i think of more ill repost.
Enjoy.
