uggh. was just trying to confirm the things about 6.5" sp in doors and the signal being sent to rear 6x9's, but crutchfield was no help. I thought they were a real leader in this type of thing too.
- basically they are saying that only component 6.5" speakers will fit in front door, or down to 5.25" speakers.
- Then rear doors will require use of the new speaker grille as opposed to Acura oem grille.
- lastly they say full range signal to rear 6x9 speakers.
Are they incorrect in all 3 counts?
Quote from crutchfield chat:
Hi, Steve, my name is xxxx. How may I help you today?
{steve} 2004 Acura TSX - looking for replacement speakers. I was under the ipression that 6.5" will fit in front/rear door locations but online it only says 5.25??
{xxxx} Let me check on that for you, Steve. I'll be right back.
{xxxx} Which location did you want to put the speakers into?
{xxxx} Oh, I see you mentioned front and rear doors.
{steve} actually want to replace in all factory speaker locations. I believe it is 6.5 in front doors, 6.5 in rear doors, and 6x9 on rear deck.
{xxxx} For your front doors there are a couple pairs of component speakers where you would custom mount the tweeters in a separate location. And the 5 1/4" offers component and regular coaxial speakers that will fit.
{xxxx} You're correct about the rear deck being 6x9's with several pairs showing as an easy fit.
But in the rear doors there's very little room for mounting height, with no speakers showing as an easy fit. There are a few to choose from if you want to custom install by removing the factory grills and use the ones that come with the new speakers.
{steve} do you have any info about only a low signal being sent to the rear 6x9, as opposed to full range signal...
{xxxx} I'll check on that for you. I'll be right back.
{xxxx} No. It appears to be a full range signal. There are no notes in the research for you vehicle that indicates just bass frequencies.
