1 - 20 of 24 Posts
I'm in the market to get new stainless brake lines. I just want some opinions/feedback from those who currently have them.
I'd like to know which brand you own and where you purchased them.
Would it make a huge difference if I got J's racing vs. Techna Fit?
Give me your thoughts.... I'd like to purchase them tonight or tomorrow.
I <3 My CL9
Don't mean to thread jack...
But is there any difference between the racingbrake, goodridge, or stoptechs? I ask cause the prices vary...is it worth it to pay $20 more for the goodridge over the racingbrake?
^^^^ i'm interested to know as well! Looking to upgrade to SS lines soon. Most likely going to go with Stoptech lines.
Sorry to thread jack, but it's on topic. Can I use OEM Acura Brake Fluid with the SS lines with no problem?
I remember that the Goodridge lines were prone to not fitting well when i was researching them back then. I had a friend who had stoptechs so went with those. Everything went well and they felt like they were quality pieces.
YOu can use OEM acura brake fluid with SS lines.
Autoanything.com
I remember I had some coupon code and bing cashback or something. Came out to be about $150 for fronts and back. The following was my order and it was about $600 total for front and rear rotors, pads all around, and ss lines front and back.
EBC Ultimax Slotted Rotors
SKU 3075418
Part # USR7087
Vehicle 2006 Acura TSX
Submodel All TSX models
1 $166.87 Ships between 03/04/2010 - 03/08/2010
UPS Ground $166.87
SKU 3075567
Part # USR7209
1 $117.39 Ships between 03/04/2010 - 03/08/2010
UPS Ground $117.39
EBC Red Stuff Brake Pads
SKU 2351391
Part # DP31610C
Submodel 2.4L 4-cyl. engine
1 $84.30 Ships between 03/04/2010 - 03/08/2010
UPS Ground $84.30
SKU 3580687
Part # DP31193C
1 $73.63 Ships between 03/04/2010 - 03/08/2010
UPS Ground $73.63
StopTech Stainless Brake Line
SKU 3567674
Part # 950.40005
1 $85.95 Ships between 03/04/2010 - 03/05/2010
UPS Ground $85.95
SKU 3567763
Part # 950.40502
1 $80.95 Ships between 03/04/2010 - 03/05/2010
UPS Ground $80.95
Discussion Starter #11
Thanks for all of your feedback... I was looking at the StopTechs and you have to buy the front and rear separately. I guess $165 is a reasonable price for both, right?
Discussion Starter #12
Ha, I didn't see that post above my last one until I hit submit.....
That answered my question!
Thanks tekneek
No problem. make sure you guys bleed the brake lines after installing the lines. Air bubbles get into the lines and you have to push them out. I had a buddy help me and you have him/her gently press down on the brakes (not all the way down) until you no longer see bubbles in the brake fluid lines. You'll need plastic tube to attach to the brake line nipple thing and thats where the fluid will come out from.
Also might as well do the rotors and pads while you're down there :)
pedal damn it
Autoanything.com
how long have u had this set-up and how has it held up? brake dust? squealing? stopping power? any up close pics of said pads/rotors? looking to redo mine soon.
how long have u had this set-up and how has it held up? brake dust? squealing? stopping power? looking to redo mine soon.
About a year and its still great. No problems from the install whatsoever. Brake dust happens but its expected. It doesn't squeal and the stopping power was an improvement and i would definitely buy again if the price is right.
I have the J's Racing SS Lines on my CL9 but I honestly think they are going to be identical to the stoptech or goodridge ones. Just make sure whatever brand you get, they have the mounting brackets built into the lines.
I buyed the Russel brakes lines. they are near 2 years old and still perfect! (winter driven!)
i changed oil for Motul RBF600, and brake fade is away!
1 - 20 of 24 Posts
