1 - 2 of 2 Posts
2006 Acura TSX 6MT
Hey all, this is my first post on the forum since I’ve been unable to find someone else with a similar problem on here. Recently my 2006 TSX 6MT wouldn’t crank at all after letting it sit for a couple of weeks. After trying to charge the battery, I had the same issue. Changing the starter relay did nothing for me either. I was able to get it started by jumping the two vertical prongs on the left side of the starter relay under the dash.
At this point I’m suspecting that the relay isn’t getting power somehow, since I’ve already tried to replace the relay and that didn’t fix the problem. I also popped the relay into a tester and it clicked on just fine. Any thoughts? Your suggestions would be much appreciated. Thanks!
1 - 2 of 2 Posts
