Hi folks new member here thanks for the invite! I need your help! I have a 2006 TSX with a starting issue. After sitting for 2 or more days the car wont start, battery is low. Alternator is charging at 14 volts. Battery is only one year old. Changed out starter thinking maybe it is drawing too much power? Also disconnected bluetooth module as this was thought to possibly cause battery drain. Only other issue with the car is door locks on passenger side don't work. Could the car alarm be an issue, causing drain? What else can i check? Any help is greatly appreciated!!!
