I need help! I want to lower my 2011 TSX sedan just a little bit. I have been looking at the Ebiach Pro-Kit and the Tein High-Tech Luxury Master springs. From the research I have done I can decide if I need a camber kit or not with these two setups.
I have lowered 3 Civics in the past (so not new to lowering with springs) and have never used a camber kit. I have mostly used the Ebiach Pro-kit. From my research Acura’s seem to be a bit more sensitive to suspension changes. Is this true?
I have also never used coil-overs , as they have scared me in the past as having rougher/stiffer rides. I’m looking to try and retain the stock ride quality with a slight drop. Is this true about coil-overs?
Thank you guys for all the help!
