21 - 36 of 36 Posts
interestd.. the RDX may have small or big.. throttlebody cause it's turboed.... =D.. but 80 bux!! Sign me up!
I don't see a thread on this, so starting this one...
16400-RBB-J02 04/05 TSX 60mm
16400-RBB-A01 06-08 TSX (GMA9A) 64mm
16400-RWC-A02 08 RDX (GMA5A) ??mm
16400-RKB-003 2007 TL/TL-S (GMA3A) ??mm
16400-RYE-A01 MDX (GMC1A) ??mm
Anyone know the sizes for the TL and RDX TB's? And if they are compatible with the TSX IM?
I have a 2005 TSX All OEM no mods yet .. I need a New TB So i was thinking Since the one for 2006-2008 is cheaper for some reason .. would that plug and play into my TSX? or would one of the others plug and play and be cheaper? I am looking for new and OEM and Plug and play and the most cost effective. Thanks any advice would help ;) (Also I understand anything other than the one made for my car will not boost performance, But understand that this is not for a performance boost.) Thanks in advance ;)
Bardi
The Accord J35 TB is a plug and play and it is cheaper than the 06-08 TSX. There are the same size too!!
J35 DBW throttle bodies - 8thgen SI - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
If you contact AutoFair they can you hooked up and get you the right vacuum fitting as well. See here Brand New OEM 68-64.5 mm DBW throttle body Stupid Cheap - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Thank You Thank You! ;)
16400-RKB-003 2007 TL/TL-S (GMA3A) 68/70mm
hey wanted to know what gaskets would I need to bolt on the 07-08 tl types tb I found one just want to hold off until I know what I need
16400-RYE-A01 MDX (GMC1A) 64mm out, 68mm in
I had to tap the top MAP spot for a vacuum line but it accepts at 1/4" NPT tape without having to drill it first.
You'll need a hose with an ID of 72mm to fit around it.
Also, a stock RBB manifold will need to have part of the manifold ground off to make room for the electronic part of the TB. I'm running a Skunk2 Pro Series IM and it doesn't need anything.
I didn't need an adapter plate to make this bolt on. But another thing to note is that my coolant lines are bypassed as well.
21 - 36 of 36 Posts
