Hello TSX'ers
My TMPS sensor for front right passenger side wheel is acting strange. I have 29 on both driver side wheels and 28 on both passenger side wheels (i know 32 is recomeeneded but its hot so the pressure will go up)....... now its only showing me the warning sign for front right tire(28) i went get air checked on tires and hey were fine..... So any help with be greatly appericiated :) thanks:2guns:
My car whines
Front tires are suppose to be inflated to 32 psi (cold) and rears to 30 psi (cold). You're 4 psi below the factory recommended spec if you only have 28 psi in the front passenger tire.
Yeah i went and got it to 32and now its good but usually light comes on when its below 5psi. Stange
Sensors fail, too. They have non-replaceable batteries and can do strange things when they start to die. The typical lifespan is about 5 years.
Discussion Starter #5
Ooh thanks for that info . i didnt know that i have a 07. And its been 7 yrs so maybe soon ill need new tmps thanks for the inputs....
