501 - 512 of 512 Posts
Not gonna lie I was for sure expecting you to forget about the tsx once the M was back up and running but nice to see that it'll come back even better... currently waiting on my asp3 to come in and as always appreciate the help whenever I ask questions on the gram haha
Sent from my Pixel 3 XL using Tapatalk
Discussion Starter #502
Haha no way! I have unfinished business with the TSX. Having the M3 back allows me to work on bigger projects with the TSX which is nice.
You're seriously going to love the ASP3 trans. Hands down one of the best mods for the TSX I've done.
J-Spec
Valve lapping is a very common practice. If you had any bent valves, it would have been obvious when you lapped them.
Are you re-using the original valve springs?
Discussion Starter #504
Good to know! The valve lapping went very smooth so I don't think I had any bent ones.
I'm re-using most of the components to keep the refresh cost under the cost of a replacement K24 long block (~$800). So far I'm about $400 in with replacement gaskets and fluids. Below is what I picked up from Acura after work on Friday. I decided to replace the chain per your suggestion and the upper chain guide from the K20Z3 per Rough Draft's suggestion. I'm a knucklehead and ordered the wrong intake manifold gasket so will need to return that one.
K20Z chain guide on the left and K24 chain guide on the right.
I'm replacing the VTC strainer filter which I suspect was leaking most of the oil up front.
I spent the majority of Sunday in the garage cleaning and prepping everything to go back in.
I don't know why but looking at this grimy hood latch everytime I popped the hood really bothered me.
Used the same bucket of Simple Green I used on the cylinder head and other parts I've had sitting over a week.
Cylinder Head torqued down.
I ended up taking the cam caps and cams back out after this photo as the rods the rockers attach to had to be clocked a certain way to get the cam cap bolts through. Once I had the cams torqued I set the cams to TDC and installed the chain. I called it a night from there. Will chip away more this week after work.
Discussion Starter #505
I've been knocking out a few things on the TSX here and there throughout the week.
I got the TCT bolted on and timing set on the chain.
I cleaned the timing cover and installed a new seal on it.
I replaced the driver side transmission seal. The old one was ripped and leaking oil.
The O-Ring for my water pump housing was stretched out and not sitting inside the recessed hole on the housing. Picking up a new one today so I moved on to the intake manifold which was super dirty and gunked up inside along with the throttle body. I took this time to disassemble everything on the manifold and give it a simple green bath.
I've been soaking all of my bolts in this Evapo-Rust solution and it works great! These are the bolts for the manifold I removed before cleaning it.
RBC Manifold and J35 throttle body ready to go back on the car.
Not pictured is the timing cover glued back on. Motor mount bolted up. Front knuckle and axle removed and reinstalled for the oil seal replacement and a few other small items. Hoping to wrap this up by this weekend.
Discussion Starter #509
I picked up the replacement o-ring I needed for the water pump housing that bolts to the block. Everything else went on pretty quickly after the housing was bolted up. I was able to fire up the TSX on Saturday night and happy to report everything seems to be running great.
Old, stretched o-ring
New o-ring
Front coilovers bolted back on
My friend Jeremy rolled over in his 98 ITR and we did some adjustments to his JRZ coilovers
J-Spec
Looks like you have the Hard Race upper control arms.
I'll bet you didn't know that the TL upper control arms are 15mm shorter.
On a TSX with stock knuckles that should equate to about -2.25 degrees of camber.
Discussion Starter #512
Did NOT know that. Good info! I'm currently at -3.0° up front with a little more adjustment left to go.
