1 - 2 of 2 Posts
TOKYO (Reuters) - Toyota Motor Corp. will repair about 1.53 million Avalons and other vehicles globally for problems with the brake master cylinder seal and fuel pump wiring, with most of those to be recalled in the United States and Japan.
The announcement comes less than 2 months after a recall of 1.3 million Corolla and Matrix cars in the United States and Canada carrying defective engine control modules that could cause the vehicles to stall.
Including the latest action, Toyota has called back more than 14 million vehicles in the past year, mostly for unintended acceleration, denting its reputation for quality and attracting intense scrutiny from U.S. safety regulators.
The world's largest automaker said in a filing with Japan's transport ministry today that about 600,000 vehicles spanning 11 models including the high-end Crown sedan and Lexus IS and GS models were subject to the recalls, either for the faulty cylinder seal, the fuel pump wiring or both.
Toyota's U.S. sales unit said separately it would recall 740,000 Avalon, Highlander, Lexus GS300, IS250 7 IS350 cars to replace a brake master cylinder seal because there was a possibility that some brake fluid could leak from the cylinder, causing the brake warning lamp to light up.
Toyota will decide whether to file an official recall in other markets in line with safety regulations in each market, Tokyo-based spokesman Paul Nolasco said. The cars subject to the repairs are sold worldwide, including in Europe, China, South America, Africa and Oceania.
No accidents were reported from the 2 defects, Nolasco said. He said Toyota does not disclose estimates for recall costs, and had no comment on whether the repairs would have any impact on its earnings.
Discussion Starter #2
RL & Odyssey Recalled as Well
TOKYO – Toyota is recalling 1.53 million Lexus, Avalon and other models, mostly in the U.S. and Japan, for brake fluid and fuel pump problems, the latest in a string of quality lapses for the world's No. 1 automaker.
Toyota Motor Corp. said Thursday that it will call back for repairs about 740,000 cars in the U.S. and 599,000 in Japan. The remainder are in Europe and other markets around the world. Honda Motor Co. also said it would recall an undetermined number of vehicles because of the same issue.
Over the past year, Toyota has recalled more than 10 million cars and trucks worldwide for a variety of problems, from faulty gas pedals and floor mats that can trap accelerators, to braking problems in its Prius hybrid. In August, Toyota recalled 1.33 million Corolla sedans and Matrix hatchbacks in the U.S. and Canada because their engines may stall.
The majority of vehicles this time around need to be fixed for a problem with the brake master cylinder which could lead to weaker braking power, said spokesman Paul Nolasco in Tokyo. Some models in Japan and elsewhere — but not in North America — have an electrical problem with the fuel pump which could cause the engine to stall, he said.
No accidents have been reported from the two defects, he said.
Nolasco said the recall decision was made under Toyota's new quality control regime instituted over the last several months in response to criticism that the company was slow in dealing with the slew of safety problems earlier this year. Changes include naming a chief quality officer to head up regional quality control teams that have more autonomy and can contribute directly to decisions on whether recalls are required.
Toyota received initial complaints about both problems 5 years ago, but that didn't mean there was documentation of a pattern that would trigger a recall, Nolasco said.
"It takes a while to compile the evidence for a recall," Nolasco said. Once the evidence pointed to a need for a recall, the company moved immediately to announce one, he said.
Analysts said the recall decision, coming just two months after the Corolla and Matrix recall, seems to suggest that Toyota is trying to be more forthcoming about safety issues. American regulators hit Toyota with a $16.4 million fine for failing to promptly tell the government about its car defects.
"Toyota's image suffered because it was slow and so it is trying to be quick with its response," said Ryuichi Saito, auto analyst with Mizuho Investors Securities in Tokyo.
The models affected by the latest recall in the U.S. include the 2005 and 2006 Avalon, 2004 through 2006 non-hybrid Highlander and Lexus RX330, and 2006 Lexus GS300, IS250, and IS350 vehicles, the company said in a statement from its U.S. headquarters in Torrance, California.
Toyota will notify owners around the world by mail to come for repairs at no charge, Nolasco said.
Honda said it would recall certain 2005-2007 model year Acura RL sedans and Honda Odyssey minivans from the 2005 to early 2007 model year due to brake fluid leaks. The company did not immediately know how many vehicles would be covered by the recall.
In a letter to U.S. regulators, Toyota said it 1st received reports of leaking brake fluid in February 2005, and found they involved aftermarket fluid that was different from the Toyota fluid installed in new vehicles. Toyota attributed the problems to the fluid and changed the rubber seals used in the brake's master cylinders to be the same as in other Toyota vehicles, it said.
From 2006 to 2010, Toyota said it received reports of the problem "sporadically" and found in all cases that the rubber seals had curled and the brake fluid was not the original Toyota fluid. After receiving more consumer reports, mostly from Japan, Toyota found that certain brake fluids contained only a small amount of polymers, which could cause the seal's lubrication to deteriorate, it said.
More tests last summer found the amount of leakage from the brake master cylinder was "very small," it said. Even if the brake warning lamp went off, Toyota said the vehicle could be driven for another 185 miles (300 kilometers) before a driver noticed any difference in the brakes. If brake fluid was not added, brake performance "could begin to gradually decline," it said.
Toyota said even with the problem, sufficient braking force remained to stop the vehicle safely. It said after another 90 miles (145 kilometers), one of the brake circuits could stop working but because of the location of the seal, no more leakage could occur that would affect the other brake circuit.
Based on that assessment, Toyota said the condition didn't present an "unreasonable safety risk." But since the condition failed to comply with a Japanese regulation that prohibits leaking brake fluid, Toyota was required to conduct a recall in Japan.
"For other countries, including the U.S., although Toyota has not determined that a safety-related defect exists, in order to alleviate potential customer concerns and avoid confusion, Toyota has decided to conduct a voluntary recall campaign in the U.S. and other countries," the automaker said.
The models affected in Japan include the Crown, Crown Majesta, Harrier, Mark X, Alphard, Kluger, Lexus GS350, Lexus IS250, and Lexus IS350. The production date of the models ranges from May 2002 to November 2005.
Two models in Japan — the Lexus GS350 and the Crown — are affected by both problems.
In Japan, Toyota's image has taken less of a beating. And despite the safety woes, the Prius has been Japan's top-selling model this year.
From January through August, Toyota sold 5.6 million vehicles globally, up 13 percent from a year earlier.
1 - 2 of 2 Posts
