Hey guys,
I wanted to switch out my fog light bulbs since one of them was burnt but I am having some trouble removing the bulbs itself. I have already removed off the screws but I realized two things when I was doing this:
1) I cannot seem to pull the bulb out of the socket, even though I pressed the clip, it seems to be stuck. Am I suppose to be doing something else in order to get the bulb out?
1) On the dirver's side of the fog light, there seems to be this black box that is right behind the fog lighs. I can't seem to pull the bulb out due to the fact that its been blocked by the box. Do I need to remove the box? Or is there another way to pull out the bulb without removing anything?
Any suggestions and comments? Thanks
· I love my CL9!
Are you having trouble removing the harness from the bulb or the bulb from the fog housing? If you're having trouble removing the bulb from the housing, you have to twist the bulb counter clockwise to release it.
hi thanks for the response. On the driver side, I can't seem to remove the bulb from the fog housing because its been blocked by this black box. Is there a way to do this without removing the boxitself?
On the passenger side, I got the bulb out of the housing, but i am still having trouble removing the harness itself.I'll try it again and see. Seems like its jammed in pretty tight.
