1 - 1 of 1 Posts
2007 Acura TSX
Hey guys, just wanted to show you my fix for my leaky trunk problem since I got the car. Found out the sunroof drain outlets were clogged and were overflowing, pouring directly into my trunk. There's also a leak on the front passenger side too, which I fixed in the same method (edited some pictures to show anonymity).
Automotive tire Water Finger Tire Road surface
Car Vehicle Automotive lighting Hood Motor vehicle
Gutted the trunk by pulling the edges and removing a bunch of Christmas tree fasteners.
Sleeve Motor vehicle Vehicle door Bag Gas
Automotive tire Wood Fender Gas Tints and shades
Right
Vehicle Motor vehicle Automotive tire Car Steering part
Bag Luggage and bags Automotive exterior Material property Bicycle handlebar
Left
Located the drain tubes. The Honda branded PVC tubes were just resting in the outlets, no wonder they just flowed into my trunk.
Vehicle Automotive design Motor vehicle Car Seat belt
I unclogged the outlets by putting the hose bit against a spigot and squeezed them around for a bit. The right side was clogged up the most. I slathered flex glue in the drain port walls first and then lubed up the drain ports with WD-40 to seal onto the body and make installation easier, then glued the outlets to the tubes, being careful not to block them.
Grille Hood Automotive tire Car Automotive lighting
After 2 days of consecutive heavy rain, no leaks and puddles were in sight.
1 - 1 of 1 Posts
