1 - 2 of 2 Posts
We recently bought a 2006acura tsx and the trunk lid will not lock shut. I notice in the glovebox is the main trunk switch. But the insides or switch is gone. Is there anything I can do to get it to stay shut. Thank you
To fix a trunk that does not close is quite easy. Open the trunk and locate the latch striker. The striker may be bent or loosened by continuous slamming. Loosen the bolts and readjust the striker. Check to see if the truck is closing. If that does not work check whether the trunk latch assemble component is moving smoothly. Lubricate it if is jamming.
Also ensure the latch area is always clean. Clean the latch and the area where it connects to the chassis. If dirt or debris has become lodged here, it can stop the latch from connecting properly.
1 - 2 of 2 Posts
